I personally nearly always opt for three characteristics in this order of priority if choice is available:
- Redundancy. With two 100Ah if one has an issue you still have ‘something’ to run with.
- Backup equipment. If something fails, I want to be able swap in another component- even if not “ideal” to buy the time to fix or order components to get out of the problem
- Long-term perspective. Even if ‘accepting’ an economic choice that is sub-optimal long term, does it enable a better 6-month or 12-months situation? If not enabling a better plan in 12-months or whatever then I should choose either a solid longer-term solution - or the oft ignored option: do nothing. Not forever but do nothing and make a plan to create the cash in a reasonable time to buy in to the 5-year or 10-year best economic outcome.
- BONUS: Scalability. Can I slide in additional capacity without rebuilding the entire system
In my case I had informedly decided to purchase two 100Ah lower-tier batteries that didn’t have a lot of complaints, but discovered that I could buy 140Ah batteries for essentially the same cost so I bought those because ‘long term’ I could add one more 140Ah and have ~2 days of storage capacity without rebuilding the system.
In your case I’d buy two 100- or 140Ah batteries and fuse separately to exceed your criteria.
I’d do the 200Ah with two batteries….
Longterm charging when no usage occurs is generally detrimental to LiFePo- they can and prefer to sit at, say, 70%
If using continuously just charge and cycle. You have the batteries to use the power, so use them. Whatever 5% lifecycle reduction- if that- isn’t a scary thing to avoid: it’s just part of having a usable system. “The cost of doing business” if you will.
Well the same principles apply. Even if not using 12V devices. I was incorrectly assuming a 12V system but the priorities of selecting don’t change, just the cost of entry.
All the more reason to ‘mask’ the deficiencies with some solar. At the least it will disguise any capacity limits with a “delay” because daytime usage will get compensated and perhaps the batteries will get fully vaccinated with capacity on a daily basis.
Define your goal in three sentences, resolve that to three short bullet points. On paper.
Close your eyes, ears, and mind completely; freeze “what ifs” and buy/build to the bullet points. Get it running.
Then let circumstances in six and twelve months reveal how to manage the future once it arrives and reveals actually what happens in practice.
Sorry: totally entrepreneurial approach here, basic decision making just without the considerations of how to achieve a profit you normally want in business.
But it’s the only way I know how to achieve goals. I’ve never been able to buy a gallon of milk with warm fuzzies?
