Hi guys, was lurking around for some time but as I now about to start my own build I have some doubts and questions...
The installation will go on the top of a 2016 VW Crafter LWB (basically, same as a Sprinter) which will have 2+1 air vents and a 4G aerial on the roof so right spacing is crucially important. Budget is medium, but what I've gathered from Will's videos with solar panels cheap does not necessarily mean shit...
The top of the van is 4,100mm x 1,400mm (161.4 x 55.1) so initially, I decided to go with 6 pieces of 150W panels: 2 next to each other and 3 rows. They are 920mm x 665mm (36.2 x 26.1) for roughly £110 (UK) which would give me 900W max roughly on a 3,000mm x 1,400mm (118,1 x 55.1) combined surface which I would say decent enough.
Now, commited to buy I had a final look around and I have find said solar panel in the title coming from China. I am a bit sceptical, sent a message to the seller to see the data sheet on the back of the panel, but I've thought I'd ask you guys as well.
So the specs are:
240W (says 18V, but no amps, no Voc, nothing)
670mm x 780mm (26.3in x 30.7in)
flexible panels
£90 so roughly 10% cheaper
This would give me 960W in a 2x2 config or a whopping 1.4kW on pretty much the same surface (actually, a bit less) as the 150W panels.
Is it a big fat lie about the wattage or did somebody actually see a panel like this IRL?!?
pm. There is a 340W version (see attachment) but that's currently out of stock...
So the specs are:
flexible panels
