robert_melton88
First DIY RV Victron system. After finishing install and setting parameters, I allowed the system to run for over a week before finishing up by connecting a Orion 24v-12v converter to my factory lead acid batteries (two wired in parallel). System worked perfectly, with 0%-.10% deviation between the two 12v280ah SOK batteries wired in series, as read by the Victron smart shunt. Only issue i had was the smart shunt SOC would deviate from blthe batteries SOC from the BMS, even after 100% twice, the two reading (shunt vs BMS) would not remain the same at all. Smart shunt would show much lower the more discharge... but that's not my #1 issue right now (help with that would also be appreciated)
I decided to finish the system by wiring the Orion 24/12 converter to my factory lead acid batteries per diagram from Explorist life solar. There are two 12v batteries in parallel that were in need of a charge. Off the converter, I wired positive to positive terminal of bat #1 and negative to Negative terminal of bat #2. Everything was fine after a several hrs so I called it a night. When I woke up, the Multiplus was off (low battery). After checking the Shunt readout it alerted low battery voltage and 111% deviation. SOK BMS confirmed with one battery at 30% and one at zero. I'll try to attach the diagram I got. The only two differences is I didn't use Orion chargers for alternators and I have 150a DC breaker after the Orion leading to the lead acid 12v's. Also there are two 12v lead acid batteries. Not sure if that matters. Any help would be greatly appreciated. Currently re-balancing the lifepo4 batteries now with Orion disconnect.
