Zero_PD
Dusty in the desert on starlink and -need some help. TLDR if anyone knows anything about BMS communication and solar inverters let me know.
We have four growatt inverters wired in split phase. They’re connected to a server rack battery bank of 9 batteries, 3 different brands. I have the growatt set to Li and CAN communication protocol.
When we fired everything up one of our four inverters started shrieking and its battery current protection fuse blew. 125a. We still don’t know what is wrong. However, our other two inverters are on another fuse. They appear unaffected. So we have just been troubleshooting with them each set to a different phase. The problem is now we cannot get any BMS communication to work. Typically we use can protocol and it just won’t work so our robots shut off in 30 seconds because it won’t see the battery. I don’t know a ton of the technical details of the communication, but we’ve never had a problem setting it a can and plugging in the ethernet cable and seeing at work. Something is wrong and I have tried switching between CAN and RS4845 and the ports on multiple batteries. And switching the comm mode on my master split phase inverter. It just won’t see the batteries. I’m stuck.
Something is wrong on multiple levels and I don’t know what. I am tempted to just go to a user to find battery charging mode, well that is definitely skipping over or ignoring an issue that we have not yet identified. I am wondering if my communication wires could be programmed or wired up incorrectly, but I’ve double checked them and they look fine. And I’m not sure how they might affect BMS.
Any ideas what might be going on? I’ve attached a few pics. Thanks.
