My problem is simple: Overkill is backordered, Daly gets bad reviews...all I need OR want is a plug and play BMS with low temp cutoff. I don't want to program it, attach relays etc. I am making two batteries, each with 200ah, 12v. 4S. The two batts will be paralleled, each one with a BMS, totaling 400ah
I wanted to go with SOC but they are out of stock till July. I looked at Heltec but am confused as low temp cutoff.
Anyway, everything I've looked at seems to either lack the low temp cutoff OR is a hassle to setup.
Anything out there like the Overkill?
