Help building my solar system for my sailboat
guitarman60
Ft. Pierce
Hi. Chris here.
I'm in need of help to put together my solar system for my sailboat. I'm looking at buying 2-100 watt grape solar monocrystalline panels. I need to know the most efficient and propper charge controller and inverter for me on a modest to poor man's budget.
I'm liking the victron 100/30 charge controller. I'm not sure on the inverter but I know I want mppt.
We need a lot more info to help you. Besides an inverter, what are you trying to do with the solar? Charge a starting battery, house bank or both?
What type of battery, lead acid (FLA) / other conventional type or lithium (Lifepo4). What voltage and Ah capacity.
What are you trying to power with the inverter?
200 watts on a boat isn't much power. Will be good for maintaining batteries and day sailing/weekend cruising.
I second, 200W of solar is not a lot.
Victron MPPT are awesome and are relatively affordable for the low power one.
Keep in mind that is best to put panels in parallel because there is a lot of shade on a sailboat.
Hi. Chris here.
dont waste money on 100/30 charge controler for 2x 150 solar panel victron 100/20 is overkill victron 70/15 is for you and 200 shaded solar panel
but also don't waste money on 2 x100 solar panel buy 350W solar panel size 170 cm x 100cm +- pick best on market trina,long, and other good Chinese brand. or best
SUNPOWER Solar panel MAXEON 425W +-
Takes up to 400 watts of panels, a 75/15 controller takes up to 200 watts and is just over half the cost of a 100/30.
If you will be adding more panels in the future then the 100/30 will allow that.
On a small sailboat 100 watt panels may be more practical than larger panels due to limited space.
Unless there is a real need for AC power an inverter is best avoided. Most stuff on a small sailboat is 12v dc.
75/15 controller takes easy 300 watts on a sailboat
No personal experience living or mounting panels on a sailboat, but I do know smaller panels are easier to handle and mount/deploy. I use 200 watt size on my RV. The post about a lot of shade on a sailboat made me laugh tho. What??
