Rudy1
After a really bad situation with a solar consultant/home builder, I have had to install and figure out the existing equipment myself - with the help of an electrician who build his own home on solar - it has been a very challenging journey. Not tied to the grid, my calculations suggest I should be able to fully charge the (8) 48V 200Ah batteries tied to the (2) 10KW hybrid inverter systems to 76.8KW - having 92KW full sun exposure to the panels over 5+hours. I have (48) 370 W panels = 17, 760 Watts/Hour.
The problem is that with full sun, the most charge I have gotten on the batteries is about 30% each - with each of the two inverters stating 20KW iintake. I still do not know what Battery C and Battery D refer to on the display. It has been challenging keeping the house powered with a long streak of cloud coverage. I believe the problem lies in the inverter settings - not an issue with panel efficiency/wiring or battery health.
Question: How many amps can I set the hybrid inverters for the charge current to safety and effectively get a greater daily charge on the batteries? The default charge current on the controller/inverter setup was 40A. I have increased it to 100 amps on master and on slave. The 48V 200Ah battery instructions from Greensun were very poor - though I did see one figure that stated 0.1-0.2 (total) for charge current. If there are 4 batteries on each inverter, does that mean 10 -20% of the total Ah is an appropriate setting - namely 4 Batteries x 200Ah x 10-20%= 80-160 Amps? I do not want to create s safety risk or damage the batteries - and customer service has been all but silent in my requests for help.
Any guidance would be greatly appreciated. I am new to this forum but am "all in" as my family depends on this system - with the help of a diesel generator on loan when needed. We just went "live" in December and still need to do cable management and design a better tilt brace. My sons and I built the 8 panel systems ourselves and got through this by the grace of God. Thank you! Bob, TN
