sunshine_eggo
Victron's little biatch
So, i can go with 3 panels in parallel with just one Victron 100/50 SCC ? Not overcharging or burning the equipment? I know they are only 10.77 amps by the sticker, so in theory they should work ok with 50 amps scc. Sorry i am a completely inexpert in solar at present time, just learning. I am running two panels flat on top, and another two sliding over them.
100/50 is limited to 100V on the input and 60A on the input. You're at 50.1Voc and < 35A.
You could, but you would be over-paneled and miss out on about half the array rated potential.
You would only harvest a maximum of 700W out of your 1350W array; however, you would harvest that 700W for as long as your 1350W array will output 700W, i.e., probably for at least a few hours a day rather than just at high noon.
