Help Designing Off-Grid Residential System.
MaxRain100
Hello everyone!
I am having a hard time designing a system that's safe, and as effective as possible, considering that my home State of Oregon doesn't get as much sun as Arizona. Learning about solar sytems, while trying to decide what components to buy, and how those components may help ensure the safety and effectivenes of the system has proven to be a chalenge for me.
My intention is to build an off-grid 48V system. And I will be buying 100Ah LiFePo4 battery cells.
The only items I have bought so far are:
- 16S BMS from Overkill Solar
- EG-4 3000 EHV-48 inverter / charge controler
The area where I live doesn't have any trees or tall structures that would cause shading, and the pitch of my roof would not cause any shading, however I can only fit 4 panels on each side of the roof (8 total) due to home size. This makes me think that I need to buy panels that are at least 250W.
I am hoping this community can help me design the system and source the components to make it work.
Well, I'll start the default answer to these questions and we can work from there. Here's you To-Do list:
1: Power audit! This will give you some important information on how big your inverter needs to be as well as how much battery capacity you'll need. There is a link in the FAQ section (I think, or someone here will post it shortly) so fill in the blanks and see what it comes up with. You'll probably need some sort of Kill-A-Watt to get accurate measurements. Are you going to be running a 12v system? 24v system? 48v system? What are the specs on your solar panels? VoC? Vmp? Being as this is a new build, throw together a wish list of what you want and estimate on the high side.
1a: Where do you live? Speccing out a system for Scotland is a LOT different numbers than Arizona due to the amount of light you actually get. Someone here can post the link to the PVwatts.com or JCR Solar Uber-Sun-Hours calculator sites to help figure out how much you'll have to work with. That will be a box in the Power Audit form.
2: Parts list: You don't need a make & model list, just a parts list to start from for reference. You'll need an inverter, a MPPT charge controller, fuses, shunt, buck converter, batteries, wire, etc. Once you have a basic list it can be fine tuned to make & models after that. If you're looking at the All-In-Ones check for correct voltage outputs (120v or 240v Split Phase for North America, 220v Single Phase for European type areas) and make sure it has enough capacity for a little bit of growth and fudge factor.
3: Budget!: Steak is great but doesn't mean anything if your wallet says hamburger. :) Figure out what you're able to spend now vs what you'll have to cheap out on now and upgrade later.
4: Tape measure! Figure out where you're going to stick all the stuff you'll need. A dozen 3000AH batteries sounds great until you're sleeping on the floor because there's no room left for a bed. Is there a compartment that can house all this stuff? Will the server rack batteries fit? Are you going to have to make space? Physics can be pretty unforgiving.
5: Pencil out what you think you need and throw it at us so we can tell you what you've missed (because we ALL miss stuff the first go-round :) ) and help figure out which parts and pieces you're going to want to get.
Thank you.
I have lots to learn, and lots to do.
You are pointing out a lot of good info.
I have decided to build a 48V sytem.
I just bought a couple of kill-a-watt to find out the power needs of my full size refrigerator, and a 6Cf chest freezer, an electric tabletop grill, and other energy hogs I cannot do without in case of another major winter storm leaving me without power for a week.
I have a modest monthly budget for this project; so waiting til I have enough funds to buy something has often left me with no choice but to wait for stuff to be back in stock, however, you are correct and I have to do my due dilligence if I want this project to be a success.
Thank you again for your reccommendations.
Once you've got an idea of what you need, the picking out parts gets to be the fun part. There are places you can cheap out and places that you really shouldn't, so that Venn diagram of want/need/afford is a little movable.
