Hello from Ohio,
2006 sprinter conversion van.
Building system using 16cell 3.3volt = 200 ah 12 volt battery bank last year
Purchased and installed Tracer 4250 BN charge controller a year ago. Mounted but never integrated into van. Also have the mt-50 meter.
Just purchased 3 150 watt panels and in process of installing, hopefully hinged roof mounted.
Just last week started using the charge controller with circuit breakers, manual cutoff etc. and temporary solar panel hookups.
Everything worked fine for a few days. Using the OK button on the MT-50 remote meter I could turn on/off the system load
from the charge controller. Although many times you would have to push the button several times for it to work.
NOW I cannot get the charge controller to turn on the load. The solid green light beside the "button" is on and with the panels
attached the left side green light blinks but I cannot get the red button light to turn on either manually or with the remote. All other functions
of the remote meter seem to work properly.
So far the highest the battery bank has gone is 13.7 volts and the lowest is 12.3 ...currently 13.4 ...No moisture problems or dropping
or any of that sort.
The only variable here is that I have a 3000w pure sine inverter wired directly through a battery protector as seen in one of that Will Prowse(?) fellows' utube
videos that energizes the entire 12 volt system when the inverter kicks in the 120v /12v converter. I have made sure though to turn off the charge controller load
whenever the inverter is to be used.
Can someone tell me where to look or what I may be doing wrong?
regards gary
regards gary
