Hello Everyone,
I'm new here and would like to know how do you have your inverter output connect to household load?
Do you disconnect the household load from main breaker and connect it to the inverter output then inverter output connect to the load?
Here is what I'm thinking for my wiring setup, please let me know if this is the right way to do and do I need to add any breaker or switch to it?
I'm also concern to the load #6, what do I do when the invert failed or need to put in services?
Regards,
Key
Regards,
Key
