Steelart99
Several weeks back, I dug a 350-ft trench, laid in PVC conduit and pulled 5 wires through my conduit. Backfilled, packed, marked with metallic ribbon (for metal detector), and moved on to installing my inverter, battery, etc. We'd had snow coming in as I finished up pulling the wires, trimmed them and spooled up the end of the wires.
So, today I finally got back to the wiring of the panels starting with the long run from my combiner box to the garage. And ... promptly saw that I had cut all my wires about 3-6 foot shorter than I need them to be. Sigh ...
So, how do I go about stretching my wire???
Okay ... so really, what would be the best technique to extend my wiring (8 THWN-2) and protect the joints? The new joints will be inside the PVC conduit.
Approx 430VDC and 13 Amps for this run.
Alternately, I can move my combiner box to a less optimal location, but "should" be able to use the wire length as-is.
Thanks in advance.
Thanks in advance.
