Venezuela Solar
- Dec 6, 2019
- 146
I just finished installing my LV2424 MPP solar inverter, but when installing the front covert i fell a small charge, i have double checked all the connections, there are no loose wires and input goes with input and output with output, L with L and Neutral with Neutral
Extra info, if i disconnect grid input (only inverter on) leaking voltage goes to 9-10v on the silver plated area (black has no trouble)
If i power off the inverter part and connect grid input leaking voltage goes to 20v
And if i power on the inverter and connect the grid input leaking voltage goes to 50v
The connecting terminals (block terminals) look ok on both input and output, the equipment works fine and this test were perform with no connection to the any circuitry in the house just a 120v outlet that i installed for maintenance and testing and is directely connected to the LV2424
I assume this is not normal, please i need some help, thanks.
