So I have a full sized truck and plan on adding the below wedge camper solution:
My goal is to become a digital nomad; I'm a software developer by trade. I want to program in off road places. My power system goal is to make sure I have a relatively hassle free experience maintaining an environment supportive of 8 hours of laptop and monitor time daily. I'm not overly fond of constantly fussing with things.
I'm initially budgeting around 2,000 for a battery solution. My truck will have alternator power run to the bed.
Requirements:
- Support laptop, monitor, phone/battery charging, electric blanket (periodically for heating solution enhancement)
Approx 75w an hour,im guessing.
- Be able to be portable outside of truck bed to work tent room.
- Give me 2 to 3 days before needing charge.
- Use solar and alternator power, ideally simultaneously.
- Be able to put this solution together in the next month or two. Im not waiting half a year. I want a February launch.
Solution considerations:
- Basically something like Will Prowse has with the alternator driven
400 watt solar solution
- An all in one solution like the Bluetti 200ac P. Possibly an ecoflow delta.
Considerations:
- A self built system seems like the best bang for your buck, but I worry about not knowing exact demands before spending more time off grid. That said, I should be able to quickly scale via series or parallel designs. There are now high quality lithium iron phosphate batteries available for approx 1000 that give you alorox 2500wh.
- If I initially launch with a self built system, how do I deal with mobility of power solution? I want to work from a tent solution at times. I suppose I could run a power cord as my truck should be close by.
- If I go with an all in one solution, like the bluetti 200ac P, I'll *probably* have all the power I need and the portability I need. But I may end up cutting it tight with power... quickly necessitating an upgrade.
Ultimately I would like to have my own system setup... with plenty more than needed power available. Say, 6000wh. But starting out, I'm really on the fence on which direction to go. I'm not I can achieve portability with a DIY system. With an all in one, I'm not getting a great value, but, get portability and ease of use. I suppose it's always possible to grab a lead acid cheaply as a backup...
Any thoughts are appreciated.
Requirements:
Considerations:
