robby
Electronic Engineer
- May 1, 2021
- 5,308
David sorry to take so long to get back to you.Hey. Thanks for your suggestions! I had just got on the roof and measured the angle that my solar panel is laid currently, it is at literally 77.7 degrees. Could that be the issue during my winter season? I want to explore every bit of option to not go with the more expensive solar panels. I would really like to stay with my Jinkos, they perform much better than my Canadian ones, and the cost isn't space reaching. Awaiting reply, Vermont citizen!
I am just going to give it to you straight.
You are not going to get any significant gains in power unless you have a Ton of money and a lot of property space to throw at this problem.
At your location in the Winter months you just don't have enough Light energy hitting each square Meter of Area to generate sufficient power and at best even if you bought the most expensive Panels on the planet you may go from 20W to 30W per panel.
The approach you would need is strings of panels eg 8 Panels in series and then parallel them with three more strings of 8 to create just one normal string and even then we are talking about maybe 650W per string of 32 x 485W panels. I am not 100% sure that is even a safe approach but I just wanted to at least present one possible solution. Now that is just one string and you would at least need one more to get up to 1300W or about 6Kwh of production per day in the Winter.
As you can see it's not very practical and in the Summer months you will literally be producing so much PV power that the MPPT will be current limited and cannot even use a quarter of what it could produce.
There are no simple answers, because you are literally trying to get water to Shower out of damp sand.
