How about high quality supercapacitors installed in the aircraft for runtime 'battery' and a portable lithiium jumpstarter for starting the engine?
Yes you can build your own battery, but it does not mean it is a good idea. Too big of a risk. As you know you can't walk or swim home from 8000 feet.Here is the battery I'm replacing: http://concordebattery.com/flyerprint.php?id=35
It's 12V, 22 amp-hours, 225 CCA, and 22.7 lbs (ouch!). Oh, and because it's for airplanes it costs $260.
Oh yea ... "airplane" means "altitude"
"altitude" means "cold"
"cold" used to mean icing of carburetor, so I used this thing called "carburetor heat"
... think you just might need to rig up "LiFePo4 heat"
Or is it going to be located somewhere warm and comfy? Do you have a climate-controlled cockpit?
Probably a thermostatically controlled, electrically powered heat tape is in order.
I didn't recognize the engine designation." IO-320-B1A" means Injected Opposing 320 cu-in (forgot the suffix stuff long ago), so no carbies there.
Carb heat, when applicable. is not done by the battery. You open a butterfly valve on the carb box that allows the carb to suck in air fed from a shroud around the exhaust.
Well weight and balance are really important on a plane and the battery is a heavy and easy thing to move to adjust the W&B during the design stage
(If you don't, you will)
Here aircraft are allowed up to 20,000' without pressurized cabin or oxygen, I think.
