Help Needed: Battery Powered Pump or Solar Pump?
jolondon
Costa Rica
Greetings. I am relatively new to solar so sorry if my terminology is not correct.
I am installing a 6.3 KW EG4 inverter with 4 EG4 100 AH batteries for an off grid location in Costa Rica. The site is relatively remote, forested, and extremely humid. Getting install/repair people here will be extremely difficult.
I need to install a pump for my well that will feed a 2500 liter tank that will then gravity feed a small house.
We sized the system so it could support a well pump.
Now in researching pumps I see that I can either run them AC, off my batteries, or a dedicated DC "Solar Pump" system.
For AC I followed the recommendation here and looked into Grundfos pumps. They aren't sold much here but I can bring one down from the USA easy enough. For my sizing it would consume around 1 KW. Am I correct that with the Grundfos SQ line there is no separate motor or controller needed? A brand that is sold here is Franklin Electric, and at least the models that are sold here require a separte motor and control box . I am a little worried about making things more complicated, particularly given what the 85 percent humidity can do to electronics. I dont know what the power consumption is on those.
The other option would be to add another 550 watter panel and directly wire a DC pump from companies like RPS Solar Pumps. They have an option for a DC to AC converter so that the system could switch to AC (from my batteries) if DC isn't available (no sun). I expect there would be several days without sun every month. Again this requires a separate controller and the cost would be around $1,000 more than going with a Grundfluss due to to another panel, additonal wiring, etc. The company gets good ratings for responsiveness. I believe Franklin Electric also has a solar option with a solar controller.
Does anyone have a view on whether I should use my AC infrastructure (EG4 Inverter/batteries) to power the pump or use a dedicated solar pump system from someone like RPS? In general I like to keep things simple so extending the given architecture witht the batteries seems maybe the most logical. But I am new at this so any thoughts would be appreciated.
This lends itself very well to low flow rate dedicated solar pump.
The kW or the kWh? The start up surge (kW) of a standard well pump might put that EG4 into an error mode.
You didn't mention a budget but if you've got enough in there for a Grundfos SQ Flex that's that ideal solution for you. It can run off of solar directly or AC from your inverter.
Thanks for the info. Grundfos says its soft start feature will reduce the startup load. https://www.grundfos.com/solutions/...-sq-sqe/sq-sqe-protection-features-soft-start. If I had to go SQ Flex I would but think it's probably overkill. I also could try and schedule the pumping for evenings or times when other electrical load is low.
The other thing is as I will not be pumping that much every day any solar infrastructure I dedicate to the well may not be fully utilized. Whereas if I add panels and batteries I can add capacity that can be used to manage loads besides that of the pump. Also as the EG4 system enables remote monitoring I can understand my electric load from one system..rather than having to check the controller for a solar well pump as well.
Hello jolondon. This is my 1st post on this forum. I just installed a SQF pump in one of my wells (260') that needed a new pump. I decided it was a perfect time to switch to solar. We have had sa few grid issues in recent years and I wanted the flexibility. It pumps to a 5000 gal tank, so I installed a CU200 and a float switch. I also installed a IO 101 switch box to go between solar and AC. It is connected to the grid but I have a 110V male / female plug on the line in so I can easily plug it in to a generator or inverter, if needed. I Love Costa Rica. Hope you get it set up however it works best for you.
