I have the Renogy Rover 100 amp and Renogy Rover 40 amp Solar Charge Controller. I have posted a similar message in another thread. I hope it helps...
Note: The Renogy Rover 100 amp only has settings for 12 volt batteries. For 24 volt double the values and for 48 volt multiply by 4.
Example Boost Charge Voltage of 14V = 28V for 24 volt systems and 56 volt for 48 volt systems. The Rover will auto detect which scaling to use by battery voltage.
You should use the USR settings. The Rover LI settings are to aggressive for Lifepo4 Batteries.
Set to USR & set:
High Voltage Disconnect 14.5v
Charge Limit Voltage14.1v
Equalization Charge Voltage 14.0v
Boost Charge Voltage 14.0v
Float Charge Volt 13.6v
Boost Char Return Volt 13.3v
Over Disc Return Volt 11.0v
Low voltage Alarm 10.9v
Over Discharge Volt 10.5v
Discharge Limit Volt 10v
Over Disc Delay Time 5s
Equalization Charge Time 0 Min
Boost Time 10 Min
Equalize Charge Interval 185
(Note this value cannot be 0 because controller can get stuck in boost mode)
Temp Comp 0A
Unplug temp sensor from the Rover 100 amp Solar Charge Controller. Leaving it plugged in can skew charging. It is used for Lead Acid batteries and not Lifepo4.
These settings should get you started. You can adjust from there. These are the settings I use with Renogy Rover 100 amp SCC currently going on 3rd year.
I use the Renogy BT-1 Bluetooth Module that plugs in the Rover-100 Rs232 port.
www.amazon.com/Renogy-Bluetooth-Module-Communication-Controllers/dp/B0894SDTSL
With that Module I use the Renogy BT App loaded on my phone to program the settings and monitor the Rover-100 and is free.
APP for solar charge controller operation in smart PV power system. It's for solar charge controller working parameter setting and reading. All data can be displayed in a diagram. Meet the Renogy BT. a convenient way to manage and monitor your solar power system all in the palm of your hand...
apps.apple.com
play.google.com
Note that I find the Renogy Rover 100 amp SCC voltage display can be off by 0.1 or 0.2 volts (usually low) and this is common with this solar charge controller. So if Boost is set to 14.0 it will probably go to 14.1 or 14.2 volts (read with a good volt meter) which is a very high state of charge for Lifepo4. You can try higher, but at 14.1 or 14.2 volts Lifepo4 batteries are typically at least 95% charged or more.
The Renogy Rover 100 amp SCC is not a precision SCC, but can be used very effectively.
Your BMS in your battery will (or should) shut down your battery before any damage to the cells with overvoltage or undervoltage protection, but you don't want to use this feature to run your solar system since it is a failsafe. You need to program the Rover-100 Boost Voltage to a voltage below your BMS overvoltage and you need to remove your loads before the battery BMS goes into undervoltage or make sure the battery voltage never gets that low (this can be done with an automatic transfer switch when using inverter/grid power combination).
The SOC displayed by the Renogy Rover 100 amp SCC is determined by voltage and is not accurate and can be off by a considerable amount. To get an accurate SOC a shunt is needed. The Victron Energy SmartShunt is one of the best currently on the market. It has Bluetooth that is displayed with an app on phone.
https://www.amazon.com/Victron-SmartShunt-500AMP-Bluetooth-Battery/dp/B0856PHNLX
I use the Victron BMV 712 that comes with a display and a few more features, but it cost more.
https://www.amazon.com/Victron-BMV-712-Battery-Monitor-Black/dp/B084M2XYK4
Per the Renogy Rover 100 amp Solar Charge Controller manual its self consumption is only 2.7 to 2.9 watts which would only be about 60 millivolts for a 48 volt system. See attached Manual.
I suggest connecting a hall effect amp meter on the positive battery cable from the Renogy Rover 100 amp Solar Charge Controller to the battery to check if it is pulling current from the battery at night.
This is a simple DC Voltage & Current meter
This Drok is a DC Voltage & Current meter and will give approximate state of charge when set up properly.
Another thing to try is resetting the Renogy Rover 100 amp controller. Go into the settings using the front panel buttons and reset to factory setting and try reprogramming it. Push & hold the right arrow key to access settings. The password is all zeros (0000000) . Just press right arrow key to select a 0 & keep pressing until password accepted. Next select Reset and confirm. Ensure all parameters are the factory default to ensure reset worked properly. Now program to the above listed parameters in this post.
If your Renogy Rover 100 amp Solar Charge Controller is truly pulling excessive current from the battery at night it is defective and needs to be returned if possible or if not repaired.
