Hello everyone,
I'm seeking advice on how to mitigate early morning shadows affecting my solar panels on the south side of my roof. The issue I'm facing is that shadows from the attic impact the panels until about 10 AM.
I have attached pictures showing the shadow pattern at different times and also of PV watts comparing north vs south performance.
System specs:
Inverter: Deye SUN-8k-SG01LP1-US
Panels: 8KW, 5.6 South (7S2P), 2.4 East (6S).
CanadianSolar CS1U-400
Voc: 53.4 V
Isc: 9.60 A
Vmp: 44.1 V
Imp: 9.08 A
Solutions I'm Considering:
Power Optimizers: I've read that installing these can help each panel operate independently, reducing the impact of shading on the entire array.
Adding More Panels: Adding about 3KW of panels on the north side and ultimately paralleling it with the east. According to PV watts, if I have the same 3KW of panels on the south, the north will produce about 84% of the south energy and also produce more energy in the summer months, which is when the 8KW isn't enough to cover the usage.
Any advice, insights, or recommendations would be greatly appreciated!
Thanks in advance for your help!
System specs:
Voc: 53.4 V
Isc: 9.60 A
Vmp: 44.1 V
Imp: 9.08 A
