I have an MPP PIP 2724 LV-MR, and I'm considering 2 of these 375w solar panels in a parallel configuration. This puts me at the 750w limit. In a 2P configuration I'm also below the max 60v PV input.... but above the 15A max pv input. Is this a safe over panelling configuration? I'm thinking yes since amp is usually a draw and the fact the panels are capable of outputting more than what the inverter controller can draw should be fine.
SOLAR PANEL SPECS:
PIP 2724 LV-MR SPECS
SOLAR PANEL SPECS:
