Hello All! The responses to my first post on settings were very useful so thankyou!
I have added an AILI shunt, and brought a victron IP22 30amp charger. This is running from a Daly 200amp and Eve 280AH 4 cells.
I need to charge the setup to 100% so altered the BMS and victron to cut out at 3.65 per cell. Left it all day.
On checking it seems the cells are not balanced. Let the system settle and these are the results - any input? (I have read the guide on top blaance which is new to me, i did try disconnecting the + on the high cell and run charge, but the BMS wont power without that cell).
finished putting it together
cells at rest
on charge (note high level 2 so no amp applied)
shunt reading (rest)
cells at rest
