Help Opening AC push style connectors on inverter
cal5265
California
Does anyone know how to open this type of terminal so that I can insert the wire on my inverter? All I could find is that they are a push style.
It’s a Delta 5.2 inverter
A pocket sized flat tip screwdriver should work.
Push it gently into the square hole beside the wire.
It does not go in or open, what am I doing wrong? I’m I supposed to jam in there the screw driver?
There's a spring clip that holds the wire in it.
You have to push into the square hole hard enough to open the spring clip.
