Old_Skewler
Here is my setup:
INSIDE SHED
- 12kW Generator 240V Split Phase with 70A breaker
- 8kW Growatt AOI Split Phase Inverter
- 48V @ 100AH EG4 Battery
INSIDE CABIN
- (1) 100A Split-Phase panel inside the cabin with most loads wired 120V
I need to install a new electrical panel inside the shed. New loads in the shed: (1) 10A circuit. My understanding is that one of the circuits in the new panel will be "Cabin". The first question i have is, what size breaker should this "Cabin" circuit be in the new panel? I suspect this breaker would either be 2-pole 70A or 2-pole 60A. Am I on the right track here?
Second question is, my local Lowes carries the following panels, by EATON or SquareD. Would any of these work well on my application? This will be my first time purchasing an electrical panel and I would like to get it right the first time around. Anything these are missing or anything I should be looking for?
Thanks in advance!
INSIDE SHED
INSIDE CABIN
Thanks in advance!
