Hello, I've tried reading many posts, trainings, manuals, etc., but I seem to keep going in circles. Can someone help point me in a direction so I can decide to commit or that this is just not going to work out.
Location: Northeast Wisconsin, I live in the middle of woods. I've performed some solar path studies and should be able to get solar from 10 to almost 3 most of the year. I have to clear out some trees. Solar Radiation is roughly 6 hours for 4 months of the year down to 2.2 hours in December if I had no obstructions at all which I cannot get.
Usage: Average of 350kWh/mo. on one meter and 720 to 1720kWh/mo. on my dual fuel rate meter (dryer, furnace, A/C, Plenum Heather, Heat pump, water heater, all high 240V loads).
Netmetering system is next to nothing, $0.0035/kW.
My goal is to DYI a system that will lower my bill and provide backup on my 350kWh/mo. meter only. I realize there is almost no way to cover the other one and frankly the rate is so low it wouldn't pay anyway. My backup would include daily use of lights, devices, refrigerator (320W), Freezer 500W, and well pump (31.5A surge, 8.4A continuous). My well pump runs maybe 2-3 minutes at a time, mainly when family is taking showers. So basically looking at installing another panel, taking out all of those breakers and making a critical load panel, and leaving all the heavy loads on the existing main panel.
Panels: I am hoping a 6kW system will suffice. I will do ground mount, and try to adjust angle seasonally since I will need to squeeze all that I can to make the system worthwhile. I'm hoping to source metal to simulate the Sinclair system.
Inverter system: Looking at at least 7500W due to well pump. I keep dancing between efficiency of DC coupling, simplicity of AC coupling, and limited number of hybrid inverters. I am constantly going in circles and hoping to get direction in at least narrowing it down. I'm thinking optimizers might really benefit me (Tigo or SolarEdge), but have seen studies in which inverters like Fronius it doesn't provide much value. Please!! Constantly bouncing between Fronius, SMA, SolarEdge, Growatt, and Schnieder. SolarArk is pretty much out due to cost.
Batteries: I'm thinking of starting out small as I only need them for back up and my power doesn't go out much or for long durations. I know Lithium is preferred, but carbon is so much more affordable. I am open to building my own too, but I see mixed opinions if it really lowers the cost that much and depending on inverter communication between the two would be really nice.
If I cannot put a system together for under $14k, to perform these needs it really isn't worth it, but I'm trying very hard to make it work. I think that is everything. I greatly appreciate anyone that takes the time to read this and provide advice. Thank you a ton in advance. Any advance on sourcing equipment is greatly appreciated as well as I keep finding only the main sites so far.
