brianjennings
Hi. First post here. I have a question or two concerning sizing new panels to a pre existing charging system. I have a renogy 30 amp rover mppt controller, that charges a 300 ah li 12 volt battery. I want to get a few panels, probably used, to power this system, as close to the 30 amp limit as possible. My rover Manuel states that 12 volt panels have a range of 400 watts, and at 24 volts, that doubles to 800. I am assuming that the math here is proportional, so that at 36 volts, it would be 1200. And so on. My mppt is rated to go as high as 100 volts. I am only interested in connecting my panels in parallel. But im looking at panels within a 24 - 45 volt range.
First, how do i calculate my acceptable range for new panels, by the VOC value, or the Vmpp value, so that i can scale them to my mppt? For example. I am looking at some 275 watt lg panels, that have a 31.70 vmmp, but a 38.70 Voc. Im using the 31.70 to scale this to the controller to approximately 1050 total watts. Is this correct? Cause it sounds like i would be able to get away with 4 of these panels for a total combined wattage of 1100. Going just 50 watts over. However, these panels would be lying flat on my rv roof, and never see 100% of their max power. Im just wondering if im doing my math right, and using the right values to calculate my range.
The amperage of panels in question are rated at 8.68 immp and 9.26 isc.
My other question is, my mppt is going to step everything down to 14.4 to charge this li batt. But not the amps, with the new panels in parallel, right? They should stay compounded at (8.68 * 4 = 34.72), but at the 31.70 volt range? or would they be stepped down at the 14 volt range? And, how does my mppt convert excess voltage into amps with the arrangement I am considering (4, 275 watt panels @ 31.70 volts)? Or would 3 panels be a better fit for my system? Thank you in advance for all feedback.
