metalheaddoc
I just put together a renogy 400W premium kit that has a Rover 40a MPPT controller. It is hooked up to a Wiese 12v 100ah LiFePO4 battery. Within 30 seconds of hooking up the panels, I get a battery overvoltage error and the voltage reading on the SCC goes up to 17-18V. I confirmed that voltage at the battery terminals. The SCC is set for 12v and Li battery type. I have the panels in a 2s2p setup, but the error also happens with a single panel. I checked the stats on the 2s2p and I get 44V and about 8-9a before the shutdown occurs. I have put in a support ticket with Renogy, but I wanted to know if you guys had any ideas. This is my first build.
Jason
Jason
