miborion
Hi,
I'm really desperate, since out of the blue, my Pytes V5alpha, died.
I have cabin in which I have an off grid solar panel setup, 3,5KW of installed PVs combined with a Growatt 3500ES and a Pytes v5a.
The system worked fine, since yesterday since last summer (august 2024), for which I have the logger logs (the Growatt inverter has a logger which monitors all the battery parameters as well).
But without any warnings, the battery just doesn't start anymore.
I found my inverter shut.
When I started my gasoline power generator, just to start the inverter (usually it works only with the PVs) the battery voltage was fluctuating: first 50V, then drops to 49V and so on until 0V (this whole time the battery indicators are dead).
The Pytes battery just doesn't start. It shows nothing on its "charge bar".
One day before It was 90% charged, without any consumers, and the last log I got from the Growatt was around 3 AM when it showed 80% on SOC.
Sorry for the long story. I just cannot understand...the Pytes just doesn't start. Since it doesn't start, the Growatt doesn't "see" it in order for me to charge it.
Is it dead? Is there anything I can do? It doesn't even have 1 year and never got it emptied below 60%.
Looking forward for any adivces,
Bogdan.
PS: I have all the proper protections implemented in the electrical panel: SPD, fuse protection, etc., therefore even a lighting should've struck, the grounding should've taken the charge.
Bogdan.
