Joe BoyKey
Watts, Watts, more Watts
Had share ground on growatt and makeskyblue, caused makeskyblue to over wattage bad and was trying to overcharge batteries
Rewired this morning, and now testing. Stay tuned.....
It stops charge at 54v regardless of upper charge voltage
Nice. Then there's hope. I have NMC as well.I have mine configured to charge to 57.0 v for my NMC and it does. No issues with operation on my dual parallel setup. I do have my array split in 2 so each unit has its on array per the instructions.
I have PV on both inverters, and the inverters are paralleled at 120V. On a daily basis one inverter will stop charging around midday, the other will continue to charge. Occasionally both will stop and sometimes not resume for a day or so. Only when loads are low. I suspect, although have not been able to verify that after being in float for a period of time (how long unknown) the inverters go out of charge mode. They do not resume until battery voltage or SOC triggers them to resume (what these setting are remain a mystery.) My SOC always shows 100%, which I suspect is because with LiFePO4 batteries my system voltage is very constant varying between 52 to 54 V on most days.We just increased the float voltage to the same level as the bulk voltage at 55V and are waiting to see whether this might resolve the issue
Have you tried to set the float voltage so low that the inverter would rarely enter the float charging mode - for example 51V given the battery is LiFePo4 51.2V? Or have you tried both bulk and float at 55V, so at night the voltage drops significantly below that?I have PV on both inverters, and the inverters are paralleled at 120V. On a daily basis one inverter will stop charging around midday, the other will continue to charge. Occasionally both will stop and sometimes not resume for a day or so. Only when loads are low. I suspect, although have not been able to verify that after being in float for a period of time (how long unknown) the inverters go out of charge mode. They do not resume until battery voltage or SOC triggers them to resume (what these setting are remain a mystery.) My SOC always shows 100%, which I suspect is because with LiFePO4 batteries my system voltage is very constant varying between 52 to 54 V on most days.
I am very happy with my Growatts, really amazing inverters for the price, but if anyone knows the secrets of what triggers them to stop and resume charging I am curious to know....
It should be SBU or SOL. UTI would draw from grid first if present unless you're using this as backup to grid. Sometimes I think Ian has some weird advice.....Have tested it with UTI, SOL or SBU , doesn't appear to have any impact when utility is not present. Ian suggest I leave it at UTI
I see similar behavior - not so much the not charging in the morning. But at / around 1 - 2 pm during sunny days the batteries are full and the charge controller shuts off and the unit flips into battery consumption mode.Trying to troubleshoot an issue and hoping that other Growatt/MPPT owners might be able to help.
Does anyone know what triggers the inverters to stop solar charging after reaching float voltage and what triggers them to resume charging?
Is charge termination and resumption based on voltage setpoints, elapsed time, SOC, or something else and are they user adjustable?
The issue I am observing is that once PV charging stops after float voltage is reached it can take a long time for charging to resume, sometimes more than a day. I have a 560AH LiFePO4 battery and loads are modest so voltage is not changing much. But rather than drawing energy from the battery it would be nice to have solar meeting the load, but that only happens when the inverters are in charging mode. Once they stop charging they draw energy from the battery regardless if solar is available.
SOL would be PV first, battery if PV can't supply enough for load, and grid last. SBU is PV, then battery, then grid.
Sorry didn't see this months ago.Nice. Then there's hope. I have NMC as well.
Would you be so kind as to post your settings? Especially #5, 12, 13, 19, 20, 21
Thanks
Yes, that is basically what the manual says. One then asks, why have 3 different settings when only 2 were really needed? Both SOL and SBU will switch to grid if the value in setting #12 is hit.SOL would be PV first, battery if PV can't supply enough for load, and grid last. SBU is PV, then battery, then grid. those seem like the same thing. pv first , battery then grid..
My brother is having the same issue. One inverter will continue to charge and carry load...the other one stops charging all together. Sometimes in the mornings one inverter will simply not start charging. Only way to get it to start charging again, seems to be to turn it off and back onMy 2 parallel Growatt-3000 operate somewhat differently with one inverter stopping charging soon after reaching setpoint 19 (Bulk Setpoint), the other continues to supply solar following the load. On some days, if loads are small, both will stop charging altogether. When they resume varies, sometimes later the same day, sometimes the next day and sometimes it takes a couple of days. What triggers resumption is still a mystery but it appears to be when voltage falls below a certain value which is not directly (perhaps indirectly) user setable. I have 32kwh of LiFePO4 battery so if loads are small it can take a while for battery voltage to drop from say 56 to 52.5 (which is where I have observed charging resuming). It would be nice if the resume charge setting was user adjustable of if setting 14 is solar only that the MPPT charger stays in float and does not disconnect. I have played with all setting combinations, the only thing that appears to have an impact is setting 19.
View attachment 49634View attachment 49635
