First post so here goes ?
So i have just order 8 cells for Xuba and thier own case to put them in so thanks to reading recommendations here i am looking to build a 2P 4s 12v pack for our boat so i have the cells now sorted so next job to select the BMS.
i am not planning on trying to star the engines from the but would like to run a 1.2KW immersion heater through an inverter so >100ams load ideally and i dont really want to spend loads of money on it!
so basic balancing with low temp, low voltage and high voltage cut off
i have been considering:
123smart bms which looks to have a nice Ui through the phone and easy to setup and control nut those boards make it look like a mad science project and looks like lots of points of failure
Rec BMS looks like nice rugidised hardware but the setup and UI looks a bit old school with windows software and a laptop! and when you add all the bits up it looks pricey
the new big Daly something like a 200ah dual port they look nice but do i want to put my trust in something out of china with limited support
any thoughts on the above or other suggestions? chargery looked good but watched wills review and that put me off and the orion which i havent really looked at yet but think its expensive
thanks
thanks
