I originally wanted to charge to 53.60 but found they would slip out of balance faster, so I upped it to 53.80 and that helped. I was going through the logs and saw that wife had started the dishwasher the day they never got a full charge late that evening. That night they only went down to 52.91 but diverged a lot and I believe that what caused the trouble I have now. When it comes to float, I read many times to never use it. I set my inverter to 50v to make sure it does not come on, even batrium warns not to use the extra bypass as its similar to float. Do you have a reference for float and its safety with lifep04?@kromc5 i believe what you encountered is “normal” cell deviation for lifepo4 cells, at the top and bottom of the curve, above 3.375 and below 3.0 volts the cells will tend to swing out of balance (increased delta). There is very little available power above and below those voltages and not worth the effort I believe. My charge/bulk rate is 54.6v while my float is 53.8v for a similar sized bank two 2p16s banks (64 cells) and my delta is usually between .01 to .03mv.
