I want to order a Chargery BMS for my LFP cells. I have selected the Chargery BMS 8T as the best fit for my needs. I’m not sure about the high voltage and lo voltage cutoff part of it. Is this included in what I have listed, do I need the DCC-X00 as well? Seems that I do.
the DCC-X00...is this an electronic device or a relay based device
I think I know the answers before I order anything
here is what I will be using it with
2 ea. stacks of 8S 200 amp/hr. LFP cells
MidNite Classic 150 charge controller
Exeltech XP-1100 24 volt inverter OR MagnaSine MS4024AE Inverter, I never use both, normally the smaller
Im assuming that I need the following
1 ea BMS-8T for each cell stack. 2 units for the 2 cell stacks
1 ea DCC-300 or DCC-600,
can anybody with experience with Chargery shed any light on this.....
any suggestions will be considered,
Thanks in advance.
David
Thanks in advance.
David
