Help with estimating install cost/time
SunFox
lehigh valley pa
First post, sorry accidentally posted in the wrong forum yesterday; hello all
I am upgrading a dated outback inverter with EG4 equipment. Existing 60 Panel 260W has already been configured to 5 strings of 12 in serial, and mounting board, disconnects, and panel interlocks are in and inspected from old system, township doesn't require permit/inspection because its doesnt change the size or move any panels.
I'm too old to tackle the project myself so I will hire an electrician for that, doesn't even have to be solar specific since the panel configuration has been done. Basically Mount the Flexboss21 and FlexGrid boxes; wires to panels, electric after cutoff breaker, feed to main panel, generator wire all right there and up to code, grounding, bonding, labeled, etc. Also build the LifePower4 V@ rack with 5 batteries and 3 ft precrimped cables (be right under the FlexBoss) Area in basement, climate control, good lighting, plenty of room to work.
What I am looking for is
1) What a reasonable rate for an electrician is
2) How many hours should it take
3) What the labor cost should be
- I will be second pair of hands for items requiring 2 people
- I have researched the equipment and have the needed knowledge
- very familiar with computers, apps, setup, etc
Doesn't seem like that big a project, I'm thinking a couple days on the outside, someone with skills, probably one day, but I would like to get some input from others that have done this and possibly a recommendation for electrician in Lehigh Valley PA
Thanks in advance, excited to get rolling on this
Nice sized project! Portion of the "labor" is based on the install location.
Pictures of the locations that you'd like the items installed will help get to a more accurate answer.
Labor rates are HIGHLY location dependent.
In my area if you find a licensed electrician willing to work for 150/hour you usually call him cousin.
Thanks guys, helpful input posting picture now, hope it helps, there a little wire clutter but once the olds ttuff is out there wuill be plenty of
3 years ago I had an electrician come out with a bucket truck for replacing a yard light with an LED one. The rate was $186.00 an hour in Mid-Michigan
