Roswell Bob
What current are you running when wires get hot? #10 is 0.001 ohm per foot. The fuse will add quite a bit of resistance too. If you put a known current and measure the voltage drop on each leg between charger and battery you can figure the resistance.You might want to replace that with higher quality wire. If I just use 10 gauge wire with crimped high quality connectors, it is barely above room temperature. My rig with the 50 amp fuse and 45 amp Anderson connectors, the Anderson connector does warm up, but not the wire. Having the fuse just makes me feel better, and the Anderson connector makes it impossible to mix up polarity. Everything is a trade off.
