KeninFresno
- Sep 28, 2021
- 27
Hello,
I have a Victron 150/35 charging up two Ampere Time 12v 200Ah batteries connected in series for 24 volt system.
The inverter is a 3000 watt Giandel unit and I’m pushing close to 1,000 watts from my array. So my questions are:
1. Are there any issues with using the bolt on fuse below? I prefer it due to the clean connection it offers.
2. Can I use a 40 amp fuse on one terminal for the charge controller and a 200 amp fuse on the other terminal for my inverter?
Are there more appropriate fuse sizes I should be looking at?
3. I have a Victron 500amp smart shunt, would I connect the ring terminal to the battery post lug or to the lug the charge controller will land on?
4. Anything I should have asked and did not?
Thank you all for the assistance!!!!
Dual MRBF Terminal Fuse Block - 30 to 300A - Blue Sea Systems
Easily and economically satisfies ABYC 7 circuit protection rule by mounting on a 3/8 battery post, battery switch or bus bar.
www.bluesea.com
