Help with identifying Bluetooth module connector-JBD/Overkill BMS type
Sojourner
I'm looking for a source for the end connectors that are on the cable for JBD/Overill BMS Bluetooth module. Any info would be appreciated. Also the wire gauge of the cable. I'd like to extend the cable or make my own longer cable.
Thanks!
i suppose I should add you could just use some heat shrink and wire laying around to extend whats there to whatever length you want...
its just a serial port cable so nothing fancy, 24awg wire will do fine.
Those wires are carrying data. If you're extending them more than a few feet, you really should use twisted pair like a CAT-5 or shielded cable at minimum.
