MilbankAustralia
- Jul 13, 2021
- 18
I have a Victron MultiPlus II with 4x190Ah 12V AGMs making a 48V bank with A Victron SmartSolar MPPT with DVCC enabled via VE.Direct.
My little camping fridge has started to use ~70-100W (may be broken thermostat or need a regas, but waiting on a new fridge soon anyway).
So this morning the batteries were down to 46.7V after a day of cloud yesterday and me forgetting to get out the generator. Not good (and generator will be running all morning to boost them back up).
I went to check the low voltage cutoff settings and found the low voltage shutoff is by default set to 37.2V! Way too low to protect the batteries I'd have thought?
I gather that is to stop it shutting off with a voltage drop under load but still, that seems very low. And at the moment we never have more than 300-400W running at a time.
Considering that, I was wondering what the low voltage cutoff should ideally be set at?
I'd really like to use SoC to shut them off but I don't know how to set it up. In VE.Configure I don't have "Enable Battery Monitor" on because I don't know how to enter the settings. I know the battery capacity (190Ah), but do not know the "State of charge when Bulk finished" (which has a default value of 85%) or the "Charge Efficiency" and haven't been able to find out these values for my system either.
I don't have an external battery monitor either so not sure if it is possible, but we don't have any DC loads coming off the batteries at all so it does all come through the inverter.
Can anyone help me with these questions please?
