Ample
- Jul 3, 2020
- 88
I have 3 x 100 Ah LiFePO4 batteries in parallel.
I get inconsistent or unexpectedly lower charging rates from both my Renogy 60A solar charge controller and my 40A Renogy DC-DC charger.
For example, this is happening right now:
Clear day, Pacific Northwest, 2:30 in the afternoon, my 600W array of panels and the Renogy 60A MPPT is putting out 18A = 250 W into my battery bank which is at 50% capacity. Each battery is at approx same level of charge (about 50%) and their voltage as measured by a shunt meter at each battery is 13.3 V. The Renogy is trying to charge them at a claimed 14.4 V but only 18 A is going into the batteries.
Here's the weird part: when I fire up a big load, such as a toaster, the Renogy immediately bumps up the power it produces to 25 A or 350W. The additional current is goes to the toaster.
When I turn off the toaster, and after a short while, I can see that the output of the MPPT goes down to 18A 250W again.
It looks like when the load on the charge controller is only the batteries, the Renogy MPPT isn't putting out as much power. It's almost like the BMSes of each battery is limiting the current into each battery. I can understand this if the batteries are close to max capacity but they are only at about 50%. The 3-battery bank should be able to suck power as fast as the Renogy can provide it (theoretically, it should be able to draw at 3 x 100 A = 300 amps.
Now, if it were only the Renogy MPPT charge controller that's doing this, I might think the problem is with the MPPT. But the 40A Renogy DC-DC charger is also doing this odd thing.
For example, I started my vehicle and the DC-DC charger immediately starts to pump about 40A into the battery bank. Good.
But after a while, it decreases to 20A and sometimes to 10A. And this is while the bank is nowhere near capacity and should be able to draw as much as the DC-DC charger can deliver.
Both the MPPT and the DC-DC is set to lithium chemistry.
I'm confused why both are having trouble pumping out their max charging capabilities into a battery bank that should be hungry for power.
The configuration is simple: the MPPT, DC-DC, and the batteries are all hooked up to the bus bars in parallel.
Anybody else seen this inconsistent charging and could help me out?
