Martin-Andersen
- Apr 10, 2020
- 16
Hi Solar geeks! This is a little different. I want to build an off grid system but without the solar part
For some of you this might sound crazy. But a hifi system sounds better running on batteries, that's the best. The next best thing is to run it with AC created from batteries and that’s what I want to do.
So I need a charger, batteries and a converter. But there are so many options so I need help with choosing the right components for the task.
I lent a Goal Zero Yeti 3000 and when I was playing my hifi system was using:
I would like to be able to play for at least 2 hours and as I understand it, the battery should not be drained more than 60% so there are 40% left.
I want the pure sin converter to have very low THD. Voltages and frequency should also be very accurate.
I should be able to move the system and it should run on 230v 50Hz and be VERY quiet.
I am not going to move it around. But I should be able to take it with me, so all in one box.
Questions:
Was thinking about using this cells:
https://www.aliexpress.com/item/400...99107d1c009f81b1-1586697671423-06460-pixtzdnE
This BMS:
Pure Sine Wave Converter
https://www.aliexpress.com/item/33000537707.html
I know this is a lot to ask. If you have any tips or ideas for this system, please let me know.
- 277 Watts
- 23 Amps
Questions:
- 12 or 24V?
- Can a battery charger be programmed to start charging at ie. 40%?
- How often do I need to Top/Bottom balance? If I never discharge below 40%
This BMS:
12.64US $ 22% OFF|Daly 3.2v Lifepo4 8s 24v 15a 30a 60a 100a 200a 500a 18650 Lfp Pcm Battery Protection Board Bms With Balanced Lithium Battery - Battery Accessories & Charger Accessories - AliExpress
Smarter Shopping, Better Living! Aliexpress.com
www.aliexpress.com
