I have installed a Renogy 40A DC to DC charger in my Gen 3 Prius. I’ve put a 60 amp circuit breaker on the 2 AWG positive cable from the starter to charger. The charger to 270ah LIFEPo4 (its what I had after not using in another install) cable is 8 AWG. The charger is turned on and off with the sense lead connected to cigarette lighter socket. The “starter“ (the motor is actually started by the high voltage traction battery) battery is a Full River 55ah
it all works ok except the 60 amp circuit breaker trips after a few minutes when I use the full 40 amps without current limiting. Can anybody tell me why the 60 amp breaker might be tripping?
