Hello,
I have 6 100 watt HQST panels on my roof that will be in 2s3p going into a 40a epever SCC and I'm trying to figure out the grounding issue but I've found a lot of contradicting information. What AWG and type of wire do I need? Will I need grounding lugs? If I install on aluminum rails or strut can I just ground the rails instead of all of the panels? Can I use a jacketed and or stranded wire or does it need to be a bare solid wire? If I put in a new grounding screw on the RV chassis can I use it to ground the panels, SCC, and inverter on the same screw?
Any help is greatly appreciated.
Thanks
Thanks
