Gladiatoroverland
- Feb 13, 2022
- 3
Camper Alu-Cab Canopy Camper on a Jeep Gladiator Diesel 2022.
Equipment:
RedArc Manager 30 / Redvision Sytem
Battle Born Energy 2-100ah lifepo4 batteries
Overland Solar 2-130watt ETFE Semi Flexible Panels
Portable RedArc Solar Blanket 150watts
Inverter controlled through RedArc remotely - Cotek SP-1000
Inputs Alternator, main solar 260watts mounted on camper aluminum roof, 1 RedArc panel separate for special power needs or issues with two panels. 1 is none etc.
would also like to run a 110v through RedArc system and a noco charger for the cab battery bank as well. Have separate Solar controller up front with 65watt panel cascadia solar. But can add a RedArc bcdc25 if needed. (Right now only using stock battery up front with 65watt panel, will be moving to 2 - agn batteries in future- removing start stop battery and isolating secondary to help tie in for winching when needed). Was just thinking using noco charger upfront to keep everything charged when parked in a garage or covered.I’d go through the rear with a NOCO 110 input that branches running one to the RedArc system and one to the noco charger under the hood for regular cab batteries.
Equipment run:
Camper lights 12v x6
2 Goose neck Lights
2 12v usb chargers
1- small 12v computer fan for Dickenson p9000 propane heater
12v scirocco fan on same circuit
Adding 12v light out on back
Adding capability to control GMRS Midland Radio through camper with extra mic and switched power
Adding some extra USB/USBC/12v plugs in panel
Remote mounting the invertor
Running Dometic CFx95Dz 12v Fridge
At max will be charging Razer Blade 14 laptop preferences Mainly through usb-c charger or if needed through the inverter
2- tablets iPad Pro for spouse and our main Samsung S7 for mainly everything on vehicle and more
Camera Gear and drone chargers
Possible 12v crock pot or 12v blanket at max use
2 cellphones and 2 portable gmrs radios
12v chainsaw battery and 12 Milwaukee batteries.
12v water pump for fill and hot water shower (Note: shower heater is propane). We have a built in water tank that has 50l of water storage.
Everything else is run through the vehicle battery bank that has its own Solar.
Need assistance with wiring sizes, fuse sizes, and a basic layout. I’m pretty confident in wiring as I was a 12v installer a long time again before I had a TBI from military service. Just forgot things like asking above and want done right.
Originally was thinking of wiring for a max load of 60amps. The redvision has 5-10amp circuits and 5-30amp circuits built in. Or as shown can wire up for max load of 200amps That said I want to keep costs down. Only thing that could be added in the future is possibles of charging two 12v mountain bikes to explore from base camp. Thanks for the help ahead of time. Camper pictured can do some of the inside since I don’t have cabinets inside.
Equipment:
Equipment run:
2 Goose neck Lights
2 12v usb chargers
