smbranch62
Starting a new Jerney
I finally received my 8 cells from China (LifePo4 271ah), I'm attempting to top balance my cells. I have the XiaoXiang BMS and I'm getting the following readout while charging. I turned off the power supply when I got this read out. Should I continue to let it charge until my BMS shut it down (3.65) or was that the right move?
Following are the parameters set on the BMS. I would really like some help so I can know that I have done this correct.
Thanks for the support.
