Hi sorry to make a whole thread aboutt this I just can't find an answer anywhere on the site as to where my problem likely is.
I am having some problems with my cells or with the BMS I am not sure which is the problem. I have 4 280ah eve cells with a 4s 100A Daly BMS, all ordered from Alibaba, I tested their voltages at first and all were within 0.01 volts of eachother. (I have no idea about the quality of the cells as this is only my second Lithium battery, I have not capacity tested them).
At first everything seemed to work fine the BMS balanced all the cells to within charging/discharging and had my 4 cells connected to the bms with my positive discharge cable+solar charge cable on the positive of cell 1. My Solar negative and negative discharge on the negative of the BMS. (happy to post a pic if that helps)
Now if I draw a current of like 10 amps+ the voltage of one of the cells goes very low from 3.35V down to 2.7V. But it is not always the same cell each time it can be a different cell that has the voltage drop (I think any of the 4 in fact from my observations). The overall voltage tends to go from like 13.3V all the way down to 11.9V while the discharge is happening which cuts out my inverter is happening, but on the individual cells it is always one cell that seems to be the main cause of this not all 4 dropping together. Another thing that happened once was the BMS randomly stopped working and wouldnt provide any current and I had to reset it by re doing all the cables, not sure if that could be linked?
The fact it is a different cell each time experiencing the voltage drop makes me think it is a BMS problem? Or maybe I have set up something wrong? Or are they just bad cells?
Any help much appreciated spent quite a bit of money now on batteries infuriating to still have problems haha. Right now I am thinking I should just buy another BMS and see if that solves the problem? Just don't want to commit more money without knowing what the issue is...
