Help With Wiring Mix Match 12V
tnconcept
Hi everyone, I am new to this I just wanted to make sure that my idea is correct. I currently have 2x 200w Regony Suitcase panel I wanted to add 200 more watts and I found a great deal on two 100w. I just wanted to make sure that I am not losing AMP or Watts because of the new panel. I made a quick sketch with Paint to see if this will work. I have been reading about lower amp panels can cause loss of power so I parallel them to get the amp then I will series them. What do you guys think? The reason I went with suitcase-style is that I like to take them with me on trips or have the station at home. They are not that light-duty kind they are heavy and can handle leaving outdoor. Attached is the spec of the panel and how I would run the new ones. Currently, I have my 2 Regony in series. Thanks!
It looks like each Renogy suitcase "set" is two panels wired in parallel. Your plan to wire your two new panels in parallel together is correct. There is a small discrepancy between the old and new panels with regard to voltage and amperage. Will it be enough to notice? Probably not.
The Alt-e store has a series of videos on YouTube about connecting panels of different specs.
Great thank you so much for your response. I really appreciate it. Now it's the fun part waiting for them to come in and hooking them up.
