Lead acid is of course what it came with, and would offer the most versatility weather wise. But he will have two 60A 24V charge controllers on it, so I calculate average 14KWh solar charging... figure setup 5KW panels so max input throughout the day...
but, 30KWh of lead minimum has charging challenges. SLA isn’t much cheaper than LFP.
LFP doesn’t outgas, but has low temp charging limits, and he is planning this for mountain use... so low temp is a concern.
heating that large a trailer is going to waste a lot of watts... the inverters are in the same area as the batteries, so 10Kw 3Phase under load will put out some heat, for sure... I fear mornings will just be too cold for LFP.
MAYBE he should use SLA and monitor the temps in the trailer under use this winter, and go to LFP later if the temps behave.
LFP with low temp monitoring would prevent damage to them, but also, limit how much charging could be done, if they are getting cold.
thoughts?
Recommendations?
thoughts?
Recommendations?
