I have one LiFePO4 battery which has one cell that hits the max charge sooner than the other 3. I never did top balance the cells due to time. I am not terribly concerned about it as I am getting plenty of capacity for my needs from the two 12v LiFePO4 batteries, which I built. Also, I just ordered 16 new cells from Dacon, which I will likely configure as a 24v system, but I am still doing my research about it.
In any case, I purchased a Heltec active balancer to see how it would work at balancing this 12v 4S battery. I connected the wires per my understanding from the manual. Two wires were not used since it could balance up to a 6S battery. Once the wires were connected to the battery cells the same as my BMS, I connected the wiring harness to the active balancer and set it on the wood panel on top of the battery. A few seconds later, I felt the active balancer wires to see if everything was okay. The orange light was on. The wires were starting to feel very warm. They kept getting hotter so I picked up the active balancer to get it off of the wood. At this point, I was getting very concerned. The board got so hot that I couldn't hold it to disconnect the wiring harness, and the board felt sticky as if it were melting. I finally got the negative lead disconnected from the battery and got a paper towel and was able to disconnect the wiring harness. I seriously thought this thing was possibly going to burst into flames.
I contacted Amazon, and they are sending a replacement. However, I have my concerns about how safe these things are and am not sure I want to connect another one.
In the meantime, I want to know if I have the wiring connected properly. Would you all please review the attached photos and let me know if there is any issue with my wiring?
