If i use another App, will i have to reload all settings again ?
I think all the settings are stored on the BMS itself.
OK,, I loaded the app, but the version in the BMS stays the same,, I don't see how to update the BMS..
And the app still won't let me change the Name..
And my settings did still remain... so that part is safe now...
So I have a Heltec 200 amp by 2amp active BMS designation JK-B2A24S20P with firmware version 4.2.5It's got me baffled too,, I wonder if i can contact Heltec support ? I'll try
Also,, do the actual BMS's ever need updates ? and if so.. how does that get done ?
The app was not from the app store. I downloaded it from I believe the Heltec link from the QR code on the device.So I have a Heltec 200 amp by 2amp active BMS designation JK-B2A24S20P with firmware version 4.2.5
I am using thr ENJPOWER app version 3 for monitoring, and changing the BMS name is simple by using the pen icon after a bluetooth scan for the device.
The ENJPOWER app works perfect. I was never able to get the xioxaing app working on my Samsung phone.
gotchya...I am using the samsung tablet.The app was not from the app store. I downloaded it from I believe the Heltec link from the QR code on the device.
is this the App version or the BMS version ?I can change the name without issue on version 3.6.3
I've put it on Drive: https://drive.google.com/file/d/1XYuPVWoTgOkxcH1NLFq6LONu5HFII0VD/view?usp=sharing
Mine defaults to .01v.gotchya...I am using the samsung tablet.
So where did you get the app you're using ?
Also... I have tweaked my settings a little.. bottom voltage 3v, and top voltage is set to 4v.
But i do not quite understand what my Trigger voltage for the Balance should be set to... right now it is set to 0.005v
What should that be set to ? the manual says to set to 0.005v for batteries over 50Ah..
I found a link to the app here.Mine defaults to .01v.
Only difference between mine and yours looks to be - I have later hardware/firmware.well, SH*T
I did down load the 3.6.3v and still the same thing..
I don't know what's going on... But at least it's updated..
this was the link i tried the otherday.. their email wasn't working.. I'll try again tomorrow..I found a link to the app here.
SUPPORT - JK BMS
Fill out the contact boxes and we will get in touch with you as soon as we can JKBMS has professional Battery BMS/Battery Balancer/Battery monitors engineer team to desing high quality series BMS/Balancer/Monitors support Bluetooth/RS485/Wifi/RS232/TTL232/CANBUS for different application. Custom...www.jkbms.com
Gotta figure out how to update the firmware I guess...Only difference between mine and yours looks to be - I have later hardware/firmware.
Mine...
Hardware Ver 6.X
Software Ver 6.1.0S
Manuf 2021-01-07
Most likely the firmware is the issue here.
Well, i noticed a few bugs in this App..I can change the name without issue on version 3.6.3
Only the 200amp version does 2 amps of calibrating current. What model are you using?Well, i noticed a few bugs in this App..
My calibrating current , it's defaulted to 0.100A. And you cannot change it to anything else.
And SCP Dly = 1500.000 ( should just be 1500ms )
Another thing I learned, I thought before when you change a setting, then click OK, After you did all your setting, then you click the Li-ion Paper airplane to send it all to the BMS, I guess i was wrong, because i noticed that it re-applies all the defaults.. Grrrr.
Anyway, I am going to reinstall the other App I had before.
I also tried again to contact JKBMS, and their email system still is not working...Grrrr
