Need disconnects for the batteries (after the battery positive fuse) and for the solar panels.50 amp fuses to the solar charge controllers and a 315 amp fuse to the inverter, fuse block and batteries.
Right. At most it may produce 10 to 12 amps.100 watt panels in 2S2P won't push 20 amps. Why the 40 amp charge controllers?
: idk, cuz i based this on "the off grid king" where he has 4 on a single 40 amp controller. i appreciate the insight tho i've already bought all the big components so i'll prolly just proceed as planned rather than returning stuff.
sorry i'm so clueless. total n00b.
2) idk tbh. they're all the exact same controller so i was hoping they'd play nice without any extra effort.hard to tell what the little black boxes are in my old age even with zoom hehe; two things to mention:
1)how about a battery thermal disconnect?
I like to have a bms on my battery pack, then fuses on both poles for those special moments whenthe BMS decides to handle a short by fusing itself with a short, THEN a DC disconnect on the bat+. This makes the battery bank safety somewhat self contained. It is always handy to have a quick method to cut the battery out of the circuit.
2)regarding the MPPT charge controllers
if those are being paralleled, don't those have to be special with a synchronizing port connecting the controllers all together to work on parallel?
somewhat like paralleling inverters, they have to know about each other or "bad things may happen".
this one, but choose one that is not dual circuit.@Q-Dog, christians camper: idk, cuz i based this on "the off grid king" where he has 4 on a single 40 amp controller. i appreciate the insight tho i've already bought all the big components so i'll prolly just proceed as planned rather than returning stuff.
@Diysolar123 and derpsydoodler: disconnects like this?
Amazon.com: Battery Disconnect Switch with 2 Keys - JOYHO 6V 12V 24V Battery Kill Switch, Isolator Cut Off Power for Marine Boat RV ATV Auto Truck,On/Off 2 Position, Waterproof Cover for Key Hole : Automotive
Buy Battery Disconnect Switch with 2 Keys - JOYHO 6V 12V 24V Battery Kill Switch, Isolator Cut Off Power for Marine Boat RV ATV Auto Truck,On/Off 2 Position, Waterproof Cover for Key Hole: Battery Switches - Amazon.com ✓ FREE DELIVERY possible on eligible purchaseswww.amazon.com
