Hey, I'm mad and here to learn
The Co-op I’m with won’t spend the money to go underground for utilities so power is out every time the wind blows.
That was the biggest reason for me.
Plus the fact that they are a co-op and raise the prices whenever they feel like it.
@.12 kWh it’s gonna take 12 years of no problems to pay back and I did all the work myself.
You definitely have to have a reason other than money for doing Solar.
It’s viable for certain things but not cheaper than utilities buy a long stretch.
Except if your Utility is charging above 40 cents then it become practical.
I learned today that maybe solar is not for me if my goals are to reduce energy costs and that .13 kwh is not that bad. I was acting out of emotion, and I apologize.
Definitely no reason to apologise. You required answers to questions and ppl here are kind enough to provide the knowledge
The people here are very kind and helpful. We need the TCO of solar to come down and the technology to continue to advance. I'm sure that people who profit from traditional energy infrastructures are doing everything possible to limit alternatives. I found an example of that today when doing research on Louisiana's net metering legislation.
It may very well be practical for you to install solar but i will need to really inquire regarding our energy consumption and costs to advise. At the moment I’m in the UK but live in Australia and have seen massive savings that will pay back my installation within 4 years but that may be different for you. It is late here so will ask further questions when I’m more awake :)
I am working on this issue, myself. It's a long road.
If you want to reduce your bill, you can consider a DIY approach for auxiliary appliances around your house (as opposed to having your solar connected to the grid and home). Pool equipment, outdoor fridges, lights, and fans, etc.
If you DIY the whole operation, you might recoup your expenses after a few years.
@randd0 - Definitely try to reduce consumption where possible. Additional insulation would be a great way to start if it is practical in your house. Trying to schedule your A/C systems might give good payback as well if parts of the house are not used some times of the day.
Take a look around and see what you can easily do to lower your energy usage.
- Anywhere from 1400 to 3600 Kwh per month. My house is 3200 sq/ft and has 2 AC units and a pool. I'm not trying to go off-grid, just offset some of the outrageous energy costs.
Will take a very large system for over 100Kwh per day.
Monthly Service Charge $12.00
Energy Charge 3,334 kWh @ 0.056842 $189.51
PCA 3,334 kWh @ 0.07221 $240.75
FF-CR Rider 3,334 kWh @ -0.00017 -$0.57
Formula Rate Plan $27.71
Slr Rider 2 $2.69
RLM Rider 1 Units @ -$5.00 -$5.00
Roundup Amt $0.91
Total Current Charges for this Account $468.00
-They will allow a grid tie, and I will not borrow money. I would like a system tied to the grid with enough battery to run my fridge and a couple of window units in the event of an outage. I'm open to overseeing the installation and using subs within my network where necessary.
Forget the grid tie, the $0.13 per Kwh is cheap. For a backup system to run the fridge, you can do that cheap enough. Inverter generator might be a better choice.
As for the window units, are you cooling the house this way currently? I'd look into more efficient units first such as an inverter mini split or an inverter window unit like the Midea.
-Do I possess the knowledge today? No. But am I capable of obtaining the knowledge and building a safe, robust system? Yes.
Learn all you can first before building any system. Conservation is key, when you conserve, it not only saves you money but if you do decide to buy a generator for backup or install a solar system, the system size won't need to be as large.
The window units are only used during an outage, most commonly during hurricanes. I have a 4-ton and a 3-ton AC unit.
SEER and COP ratings?
7 tons is a big power draw. I'd be looking at some home improvements concerning insulation.
This is a common path, high energy bills spur those to look into options to reduce costs.
The most efficient use of money is to first work on the demand side of the equation, it is always lower cost to do the following than build a energy generation system ( doesn't matter the type, IE: solar , hydro, wind ect )
#1 Home insulation. By leaps and bounds this has the best payback. Most homes built lack adequate insulation, adding insulation from builder standard ( or less ) typically would cost 1-3 thousand. Pay someone to do this nasty work and at least around me, it is cheaper to pay a company to blown in the insulation than you purchase the materials and rent the machine yourself.
Typical energy savings can be 25-40%
#2 Energy audit. Find where the energy is going. This doesn't required any tools, look at the ratings for your AC/Heat pumps, pool pumps, refrigeration and water heating, the most energy is used in a typical home usage. If you wish, they have devices that you can measure actual demand to help find where energy is going.
Heat pumps have SEER ratings, the higher the better. Just replacing an older AC, heat pump could lower electric demand 25% or more. There are newer technology's, called variable speed heat pumps that can be in the mid 20's for SEER, vs. older units that depending on age maybe as low as SEER 4-8. I would recommend you take a look at the ducted mini-split systems. SEER's in the 20's, 1/3 the cost of purchase and while it may take some effort, just hire a company to use the equipment you purchased.
You mentioned a pool, that is a perfect DYI job to go with a variable speed pump for the filtration system, one could expect 50% or more lower electrical usage ( pool part of demand ) without any impact on water quality.
# Home appliances. How old are the major appliances. Refrigerator's, large screen TV's even old computers all have improved in efficiency. See what you have and compare to what is available.
Once all the above has been address is when it may makes sense to invest in Solar if the goal is reduce grid energy purchases further.
$500 a month? If that $0.13/kWh quote is true, you're using 3.8 megawatts a month. 128 kWh a day.
That's a huge amount of energy. Way too much for solar... or anything, for that matter.
I do very well with solar. I use 3 kWh a day.
i'm at 118kwh/day and that's with me being an energy grinch. we have bad windows (deposit put down for new ones) and a 18 yo 3ton unit that is an energy hog. I'm building a 13.4kwh battery bank system to power all but the hvac and stove. those are the two hogs. I also think the original ductwork in this house has horrible seals and i'm cooling the neighborhood. last two energy bills are about 575 each.
let's go brandon!
let's go brandon!
There are many things to consider before taking the plunge into solar. The cost/reward being the biggest factor. Also what I can do to make my home better to conserve energy.
Led Lighting
Energy Efficient Appliances
Insulation
Shade Outside of House From Sun
Change Your Energy Habits
What we did:
Four years ago my wife got an inheritance when her father passed. She was restricted in the use of the money. We decided to go solar on the house.
In Las Vegas NV it cost about $40k. Talked to 6 different companies and chose the middle bid. They came recomended by a friend. The tax credit was about $12k. So net cost about $28k for 28 panels and grid tie system installed, and all permits. After the first year (took about a year for the banked kw to build up) our power bill has been the minimum due to only the taxes and add-on fees. We pay nearly $13 a month. Went from $275 in summer and $250 in winter to $13 year round.
Our house is over 30 years old so insulation isn't/wasn't so good. We recently had to replace the heat-pump, and water heater. Both with high efficency ratings. After getting them installed we had new insulation blown into the attic space. Big difference in cooling the house. Much more even cooling throughout.
We also set up shading for the south and west sides of the house. Some plants and some lattice panels to break up the sun. We may even put up a patio cover on south and west sides. Another big difference. No more hot walls in the bedrooms.
In Las Vegas we have excellent sun for solar. Sun-up @ 6am -- Sun-Down after 6pm. Best sun between 8am and 5pm. Temps in 100's for 3 to 4 months. We don't have power outages (one time in 20 years for about an hour). The cost per kw is about $.13. I believe we are on an 80% sell/buy-back plan with the power company.
The solar panels cover most of the tiled roof on the south and west sides. Even if it was a shingle roof the panels would protect it and extend their life.
Solar was one of the best investments we have made.
I now subscribe to this forum and am working with DIY solar on my motorhome. I am in my 70's and cannot do all the everything I did when I was younger. When we put solar on our house we knew nothing about it and called a professional. Our system is fully insured on our homeowners policy. If I had gone DIY I may not be as insured as with a pro company installation.
Me Too: let's go brandon!
Every time I run the numbers , I get 12 + years ROI on roof mounted PV. Hence to me it makes no sense. The grid is better technically and uses my money in a more reasonable way. Capital is now getting more expensive anyway, roof PV , professionally installed , simply doesn’t make economic sense. Prices need to fall by 60 % to bring the ROI down to 3-4 years to make it financially viable in my view. ( not to mention the opportunity cost of that money over 12 years )
Your pv pricing is very similar to my quotes
