I'm pretty decent at wiring, electric, and tinkering in general, and I used to be an industrial battery equipment tech so I've got the basics of that end of the system down at least.
I'm planning a system that will keep the essentials of the house running. It will run separate and parallel with the existing wiring and I'll utilize colored receptacles to identify battery power. I don't want to backfeed my panel because I'd like to use the PV energy as much as reasonable even when we have ongrid power.
I know I could install a manual transfer switch and even have one lying around but honestly I just don't like them. The wiring inside those things looks like junk.
I'm still trying to understand how best to run a dump load to a water pre-heater. I can easily hook up a relay controlled by voltage but I don't want it to short cycle or keep the batteries from fully equalizing, but I also want it to be as efficient at using that 'extra' energy as possible. I can't believe I don't have more options for a SCC with diversion load built in!
Anyway, I'll keep reading up on it and I'm sure there's a good solution for me.
